Andreas_Sweden's avatar
Mar 17, 2020
Netgear Orbi AC3000 - Telia IPTV not working
Dear Netgear Community,
I have a Orbi AC3000 system at home with one router and two satelites.The router is located at the ground floor in my house, and the two satelites located on the second floor and is running by WiFi
The internet connecton works really well with good ping and high download and upload speed on the WiFi network.
My problem is that I can't get IPTV with Telia (Sweden) working with ny Orbi AC3000 system.
How should I configure my router to be able to watch IPTV on the WiFi?
BRs
Andreas
    • Andreas_Sweden's avatar
      Andreas_Sweden
      Hi,
      I tried the solution but I couldn't make it work. When I tried the solution for Netgear Nighthawk on my system, internet didn't work and IPTV didn't work either.
      Do you have any other possible solution to try?
      Also, on my RBR50 (router) I have 4 network connections, on the satelites I only have 3 network connection it this is valuable input.
      BRs
      Andreas
