killians913's avatar
killians913
NETGEAR Orbi AC3000 satellite LAN ports
 I keep hearing that the LAN ports on the satellite units do not work.  Is that correct?  If so, when will they be activated and be useful?
  • The LAN ports do work.  The USB ports do not.
    • killians913's avatar
      killians913
      Thanks so much for your response to my query.  So you're saying that I can connect a basement computer to one of the satellites via the LAN port?  How will the LAN connection be degraded?
      • st_shaw's avatar
        st_shaw
        Master
        Absolutely, you can connect a wired computer to the Satellite's LAN port. That's what they are there for. I wouldn't say the LAN connection is "degraded," but the speed will be limited based on the other device you are connecting to over the LAN.
        1. Between two computers connected to the Satellite's LAN ports you will get full gigabit LAN speed. Throughput should be >900 Mbps.
        2. Between a computer connected to the Satellite's LAN port and a computer connected to the Router's LAN port you will get the Orbi Backhaul speed. Throughput should be 500 Mbps or greater for a good backhaul connection.
        3. Between a computer connected to the Satellite's LAN port and a computer connected via Orbi WiFi, the speed will be limited by the WiFi client's connection.
