HirsuteKnight
Aug 02, 2017Aspirant
Netgear orbi and Bt smart hub
I've tried unsuccessfully to use the orbi with my bt smart hub. I thought it was plug n play but it's not working. Do I need to do something with either the orbi or the bt smarthub router. Apologies ...
- Retired_MemberAug 03, 2017
The best way to set this up is to disable wifi on the BT SmartHub and then use the Orbi in AP (Access Point) mode. The main Orbi unit needs to have a network cable connecting it to the SmartHub.
Alternatively you can replace the SmartHub with a VDSL modem (I use a Vigor 130) and then use the Orbi in Router mode.
Retired_Member
Aug 03, 2017The best way to set this up is to disable wifi on the BT SmartHub and then use the Orbi in AP (Access Point) mode. The main Orbi unit needs to have a network cable connecting it to the SmartHub.
- HirsuteKnightAug 03, 2017Aspirant
Many thanks. Is the Vigorous 130 easy to set up for a novice?
Yes it is. If you use BT TV you need to follow this article: https://www.draytek.co.uk/support/guides/kb-vigor-130-bridge
That makes sure the channels broadcast over your Internet (e.g. BT Sport and some kids channels) work correctly.
Hi. So helpful. I don't use bt tv though. I just use wifi for browsing, internet, PlayStation store, Netflix etc. Does this make a difference?
