alfred56's avatar
Sep 18, 2018
Netgear Orbi RBK50 DDNS issue
Hi Netgear community,
I have a Netgear Orbi RBK50 Firmware V2.1.4.16 and do not think the DDNS function is updating my host at NO-IP.COM.
The service is configured with the right hostname and credentials, but when I check "SHOW STATUS" I get the following message:
Window title: http://192.168.33.1/DNS_ddns_status.htm
Message: No update action. There is no IP address on the Internet port.
The Netgear Orbi router has a static WAN port configuration of:
IP: 192.168.0.20
Mask 255.255.255.0
Gateway: 192.168.0.1
DNS1: 8.8.8.8
DNS2: 8.8.4.4
DNS3: 1.1.1.1
The Orbi wan port is connected to a LAN port of a Telstra Gateway (AUS) Model DJA0230 setup with PPOE to connect, DHCP disabled, 4G Disabled, Wifi Disabled, DMZ to point to the ORBI router WAN IP address.
Orbi router provides WIFI, DHCP to the clients.
Any ideas why?
Thanks
Best regards
Alfred 56
  • This happens sometimes with me. I also have DDNS from No-IP.com. When this happen I just disable DDNS by unticking "Use a Dynamic DNS Service" then Apply the changes and then do the opposite. The DDNS status will show correctly after that --> xxxxxxx updated successfully at 11:01 PM, 09/18/2018
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hello alfred56,
      Have you made any recent changes to your configs when the issue occurred?
      ~Christian
      • alfred56's avatar
        alfred56
        Tutor
        Christian_R wrote:
        Hello alfred56,
        ~Christian
        Hi Christian and thank you for your reply.
        I did not make any configuration changes.
        I know it was working under previous firmware versions.
        I reset everything to factory defaults and reconfigured everything and I still get that message when I check the DDNS status.
        Perhaps some Netgear engineers should look into this.
        Regards
        Alfred56
    • alfred56's avatar
      alfred56
      Tutor
      Thanks for this tip,, it actually worked!
      I got this message this time:
      xxxxxxxxxx.ddns.net updated successfully at 08:05 PM, 09/19/2018
      Netgear needs to fix up the firmware eventually.
        Christian_R
        alfred56,
        Glad to hear you got it fixed! Thank you for your help on this ekhalil.
        Engineers are working to resolve these issues in future firmwares.
        ~Christian
    • FURRYe38's avatar
      Sounds like maybe NG enginneering could make a improvement upon the refresh function of this feature.
      Glad you figured it out.
      Christian_R
