Devil000
Oct 30, 2019Aspirant
Netgear Orbi RBK50 with 2 Satellites - Patchy / Slow Wifi performance
Hey, I have had the RBK50 around a year now and it has been amazing since day one. However in the last week or so the Wifi has been terrible. Its been slow, patchy and all round frustrating. ...
crankycder
Feb 10, 2020Tutor
I've got an RBK50 setup as well - ran completely fine from April 2017 until the last week at which point wifi just started to misbehave horribly.
It seems worse on the 2.4Ghz bands - phones can't seem to connect reliably orat any sustained speed to wifi. The 5Ghz band is also unstable.
I loaded the latest firmware last week tottry to see if this resolved issues, but rolled back and did a full factory reset. No love.
I'm running an EdgerouterLite 3 firewall so the orbi is just running in AP mode. Connectivity to the public internet looks fine by ethernet, it just looks like wifi is toast.
I'm going to try swapping out the Orbi with a newer smaller RBK20 set today. I'm pretty sure at this point something just fried the wifi circuits.
Feb 10, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
