andersen24
Sep 29, 2018Follower
Netgear Orbi (RBK53) AC3000 with multiple unmanaged switches
I am looking at purchasing the RBK53 system from Costco, but have a question about the installation. I see on the support page it shows you can go from the cable modem, into the router, then into an...
Sep 29, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. Thoght using wired back haul should not effect range and should increase it. I have not used or tested a Trendnet switch, however I have several HP, D-Link and a NetGear switches in the mix and have had zero issues going from a main switch or now using a smaller switch behind the router that carries DISH Hopper and Joeys, PC and microcell with the 1 satellite at the far end of my home.
Just besure the lan cabling is good and the switches are unmanaged. You can use managed switches if you disable ALL IGMP protocols from what others have said.
