jjvoliver
Jul 27, 2018Apprentice
Netgear Orbi RBK53 Wired 2.1.4.16, too many issues!
So, I just set up this system on Monday, July 23rd, 2018.
Using it to replace a Google WiFi mesh system comprised of 3 Asus On-Hubs.
The reason I wanted to change was that I needed more r...
- Jul 27, 2018
What is the mfr and model# of the ISP modem?
Any network switches in the mix? If so, Mfr and model# of the switches.
What is the distances between the base router and satllite and in between the satellite? 30 feet should be a good starting point.
What channels are you using? Auto? Try setting 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Heres how I got my friends 50 series up and running:
Others to review:
https://community.netgear.com/t5/Orbi/Rbr50-satellite-to-satellite/m-p/1613750/highlight/true#M38100
Jul 27, 2018Guru - Experienced User
Others to review:
- jjvoliverJul 27, 2018Apprentice
Others to review:
Infinity router is a model TC8717, WiFi is completely off, so no worries there. Then the topology is as follows:
TC8717=hardwired>RBR50=Wireless>RBs50x2 (Just removed the daisy chain topology and changed to star topology)
I do have 1 8-port unmanaged switch to LAN 2 port in the RBR50, and all my main devices pluged to it (TV, PS4, Xbox One S, Wink 2 hub, Amazon Fire TV, FingBox, Obihai VOIP box, QNAP NAS), plus the Cat6e wire that runs to the 3rd floor, but it is currently unplugged from the second (farther) RBS50. My router is in the basement, the first satellite is roughly 25 feet from the router, and the 2nd satellite is just 45 feet from the main router and 20 feet from the 1st satellite. The stairs from basement to 2nd floor are completely open, no walls in the middle, so the signal goes straight to each satellite.
So far, with the star topology I'm showing a good connection to both satellites.
I will move to channel 1 on 2.4Ghz, disable MU-MIMO, as you mention in the setup you did for your friend, and leave it there for 24 hours and come back with the results.
Thank you, I will keep everyone posted.
- FURRYe38Jul 27, 2018Guru - Experienced User
Regarding your ISP modem/router:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.Hope the new settings help it work better for you...Let us know.
- waynealightJul 27, 2018Apprentice
what problems are you having with ethernet backhaul? ive not had any issues using it, only getting it to sync after a power cycle is challanging. In my case i have to sync wirelessly then once everything is going i can plug in ethernet backhaul and it will switch over and work great.
