tutorr60
Dec 07, 2019Follower
Netgear Orbi RBR20 and Ecovac Deebot connectivity issues
Hello. I am at my wits end on connecting my Ecovac Deebot N79S to my wifi network. I have gone back and forth with Deebot support. The Deebot will NOT work on a 5.0GHz network and requires a 2.4GH...
Dec 07, 2019Guru - Experienced User
What most have had luck with is to turn down the broadcast power on the 5ghz signal during setup or you can try disabling the 5ghz ssid broadcast for setup. Once setup, you can turn it back up/on.
Take a look at these posts for more details.
