TheGuy18
May 12, 2020Guide
Netgear Orbi RBR40 router and satellites low speeds and drop connection
For the last few weeks internet has been dropping off, and is slower than normal. Normal download speeds are around 150Mb/s but most recently I am getting around 20Mb/s. The connection has also fully...
May 13, 2020Guru - Experienced User
RBR and RBS should be on same version of FW.
v16 is the most current version of FW.
TheGuy18 wrote:For the last few weeks internet has been dropping off, and is slower than normal. Normal download speeds are around 150Mb/s but most recently I am getting around 20Mb/s. The connection has also fully dropped several times over the past couple weeks. I have called the ISP (Cox) and they claim there is nothing wrong on their end and nothing wrong with the modem. I recently updated the router and satellites to the most recent firmware (.32 and .30), but that only seems to have worsened the situation.
