Stuart07715
Apr 16, 2018Aspirant
Netgear orbi RBR50
Please help I have brought an orbi system with 1 satellite and wish to extend the coverage to another part of the house which has very poor coverage, do I have to use another orbi product ie satellit...
Streak2
Apr 16, 2018Master
I would first experiment with changing the location, if possible of the current setup to give you the coverage you need.
- Stuart07715Apr 16, 2018AspirantThanks for your reply I have already tried this in a number of places, I need to get coverage to an anexxe which is built onto side of the house.
Any suggestions?
Thanks- tsigApr 16, 2018Luminary
I had one of these before getting the Orbi and continue to use it and it works fine.
- Streak2Apr 16, 2018Master
You could look at wifi extenders but they need to be carefully placed to ensure a decent input signal.
There are also the powerline extenders that work via the mains.
Whatever you choose make sure that the vendor has a good return policy in case it does not work in your environment.
Of course running an ethernet cable would be the most reliable but I guess you dont want to go wired!
- tucsonticoApr 17, 2018Virtuoso
I use an Engenius ENS202 Outdoor WiFi AP/Bridge to cover the distance (25m) to my pool equipment. My ENS202 is in bridge mode and recieves a decent signal (-55 to -60dB) from the Orbi base on 2.4gHz. If you don't/can't run Cat5 cable to the annex, consider an AP our bridge solution.
