Stuart07715
Apr 16, 2018Aspirant
Netgear orbi RBR50
Please help I have brought an orbi system with 1 satellite and wish to extend the coverage to another part of the house which has very poor coverage, do I have to use another orbi product ie satellit...
Stuart07715
Thanks for your reply I have already tried this in a number of places, I need to get coverage to an anexxe which is built onto side of the house.
Any suggestions?
Thanks
Any suggestions?
Thanks
tsig
Apr 16, 2018Luminary
I had one of these before getting the Orbi and continue to use it and it works fine.
- Streak2Apr 16, 2018Master
You could look at wifi extenders but they need to be carefully placed to ensure a decent input signal.
There are also the powerline extenders that work via the mains.
Whatever you choose make sure that the vendor has a good return policy in case it does not work in your environment.
Of course running an ethernet cable would be the most reliable but I guess you dont want to go wired!
