Acoaaxet's avatar
Sep 05, 2022
Netgear Orbi Router RBR40 will not connect to internet
I have a Netgear Orbi Router RBR40.  Purchased new in August 2019.  Router stopped working today. I have done a hard reset.  Will not connect.  Can I purchase a replacement base station without the 3 satellites or do I have to buy the entire package (base station plus satellites)?  I paid $400 for this device 3 years ago, and am surprised it failed.
  • plemans's avatar
    What is it actually doing? Some can be recovered with different methods than just a reset.
    You can buy just the router but your best bet is through a 3rd party site like ebay.
    You can use the rbr20, rbr40, rbr50
  • Thank you for your reply to my post.  We had a power failure yesterday.  After Internet was restored, we had no Internet services.  I connected an Ethernet cable directly to the cable modem, and we had service, so it's not an ISP issue.  No connectivity with Orbi router.  After several reset attempts, I wiped the Orbi router, did a factory reset and did a complete reinstall with new Orbi app and followed set up instructions as if new device.  I also did a hard reset the satellites.  After the set up, the factory network name, Orbi93 appeared; however, there was no connectivity.  My conclusion is that the device is not working -- potentially affected by power failure ---and my one year Netgrear warranty and support plan has expired.  Do you have any other troubleshooting ideas before I buy replacement device?
    • plemans's avatar
      What modem is it connected to? Not saying its a line issue but netgears don't play as nicely with double nat's (more than 1 routing device) as others do. If the modem has its own integrated routing functions, sometimes you just need to adjust a thing or to for it to show internet connectivity.
      • Acoaaxet's avatar
        Acoaaxet
        Tutor
          Hi
        My ISP is Spectrum.  We have a SMC Networks router (router only; does not include wifi) Model D3G 1604W.  Purchased router from Spectrum in 2017.  Has worked perfectly Orbi RBR40 since 2019.  I don't think its' the router which is working fine with temporary Netgear NIghtwawk X6 which I am using until I replace Orbi.
