IamNaga's avatar
IamNaga
Tutor
Jul 01, 2021
Netgear Orbi Voice (RBS40V) replacement adaptor
Hi,
I bought my Orbi Router in USA which comes with Orbi Voice (RBR40V). And recently I moved to India. After few hours of usage in India, the Orbi Voice adaptor melted and stopped working. Then i realized the adaptor is marked as 100 - 120v. My bad, I ignored looking at the voltage label for Orbi Voice as i checked for main Orbi Router and it supports 240v, so assumed the same voltage for Orbi Voice too. Lesson learned.
Now, I dont find the replacement adaptor for my Orbi Voice (RBR40V). Please guide me to get a replacement adaptor, if not Netgear any third party works? Here is the voltate info from my Adaptor
AC Adaptor
P/N: 332-11039-01
Input: 100-120V ~ 50/60Hz 1.5A
Output: 19V --- 3.16A
Model: AD2003F10
Type: 107LF   BAH
  • Hi, i just got the same issue here. have you found a solution for the adapter so far please?
    My adapter melted as well. the light is still blind white when i turn the devoice one but the devoice cannot sync to router now. i am not sure now whether the devoice might not work as well or just the adpater.
    • schumaku's avatar
      schumaku
      The original Netgear 60W, 19V, 3.16A power supply (as it's coming with e.g. the EU, UK, and AU market) 332-10631-01 Model: AD2003F10 Type: 007LF is coming as a 100..240 V AC input version and comes with US UK EU AU plug modules.
      I'm convinced Netgear Customer Service is able to offer replacement power supplies.
      Ebay, Amazon and free vendors are offering original as well as genuine Netgear power supplies - watch your step and double check voltage and plugs.
      Certainly also workable are the universal 19V, 60W notebook power supplies coming with a bunch of DC adapters. Operating a R9000 here on such a unit for a very long time - because of the original US power supply was 100..120 V only.
      Wonder where the community fellows are which are claiming that one can operate these 100..120V spec'ed power supplies on 200...240V AC 8-)
      • IamNaga's avatar
        IamNaga
        Tutor
        Thanks for responding, i will give it a try with this UK model numbers.
    • IamNaga's avatar
      IamNaga
      Tutor
      Could not find the right one yet in online. Need to explore in local stores to see if i can find a right specs with Indian voltate.
