Virtech
May 19, 2019Aspirant
Netgear Orbi VPN Woes
I'm trying to get the VPN working through the RBR50, have configured the VPN through the netgear interface and then downloaded the Windows config file.
I have the OpenVPN client running on Windows 10, when I try to connect I get in the Logs, "Enter management Password",, not sure what this is?
- Blanca_ONETGEAR Employee Retired
Hi Virtech
Welcome to NETGEAR Community!
- Do you have the latest firmware version (2.3.1.60)? If not, I suggest to update the firmware.
- What version is the OpenVPN client used?
- Are you using a Static IP for your router or Dynamic IP?
Blanca
Community Team- VirtechAspirant
Hi to answer your questions below:
- Do you have the latest firmware version (2.3.1.60)? Yes it installed
- What version is the OpenVPN client used? 2.4.7
- Are you using a Static IP for your router or Dynamic IP? Static
The Orbi VPN is pretty much useless, I was connected at once stage using a previous firmware version but it was so slow it was unusable.
Chris
- ribadiscibadiscAspirant
Can you share the solution please?
I have the same problem.Thanks
