Troyd75826
Feb 08, 2018Guide
Netgear, please please please allow end user to turn off automatic firmware updates!!!
Firimware updates 2.1.1.16 and 2.1.1.18 are totally unstable with random, constant loss of wifi. I must constantly reboot the router. Prior firmware 2.0.0.56 is very stable for me and I would like t...
t_k
Feb 09, 2018Luminary
Troyd75826
You're complete right that it's absured that auto-updates cannot be turned though the Netgear admin UI.
However, for others who stumble across this, there *is* a way to disable auto-updates, it's just not in the UI. You don't have to block the software update sites.
See the post by Butch1326, which details how to do it.
Even with auto-updates disabled, however, you'll have a host of other issue. See my related post here.
- Troyd75826Feb 09, 2018GuideYes, I have done that, and it seems to work. But we should not have to hack config files just to keep something that we know works as it is. Please read Netgear!
- webminsterFeb 09, 2018Luminary
I personally (and others as well) have found the telnet hack to be unreliable. The firewall block is the only really reliable way to block auto-updates.
- Retired_MemberFeb 09, 2018
Although allowing the user the ability to turn off auto-updates may be a positive thing, I'm curious about the following:
Number of Orbi systems sold______
Number of Orbi systems with little to no problems_______
Number of Orbi systems with too many problems_______
