buzzoff
Aug 06, 2025Luminary
Netgear stated firmware to be released to fix inability to work with iOS Private Relay
Netgear published an article, located at https://kb.netgear.com/000065057/The-Nighthawk-or-Orbi-app-on-my-Apple-iOS-device-only-connects-to-my-router-or-mesh-system-with-Anywhere-Access-What-can-I-do...
- Aug 10, 2025
Fixed I believe is a different MAC address that differs from the actual HW MAC address that is burned in to devices and would be as safe to use as randomizer is. This seems to stay unchanging and limits what other devices seen when connected using Fixed. This seems to be Apple attempt to help with some issues seen when using the randomizer that changes the MAC address every so often. So you could use this while at home as well if you feel that randomizer may cause problems.
I feel that most NG routers are handling the randomizer ok now days, users just need to be aware if odd issue they may see with it enabled and router may not indicate what these devices are when the randomizer is enabled and connected. As we see "unknown" for a device name rather than the actual device name. MAC Filters rely on static unchanging MAC addresses to make filtering work so no, having randomizers enabled would not work well for MAC Filtering. That would be the nature of the beast. Why I leave mine disabled and my choice. I don't do lots of traveling and when I go, then I enable it at that time. You'll need to make your own choice when it comes to these features. All that's up to you. No body is force you do anything. Features are there in Apple devices. Up to you to use them or not.
Any more details, contact Apple regarding there products and features. They'll have the best information to provide.
It maybe possible that with the older AC series, since it's EoL, FW may not handle the newer generation iOS features and no work well with randomizers enabled. Not sure if this is a FW issue or combined FW and iOS issue as well. I just had a 50 series online for a few days last month, did not see any log in issues with either Apple iOS 18 or Android devices having randomizers enabled.
buzzoff wrote:
Furrye38, I apologize and you are correct. I misstated using Private Relay and the issue is Private WiFi Address. I do keep it Private WiFi turned OFF.
What is different in using Fixed versus Off?
My frustration is users shouldn't be forced to remember to turn this feature on and off as they leave and return home to their LAN.
buzzoff
Aug 09, 2025Luminary
Furrye38, thanks as usual for the response.
Actually aware of the fix Apple provided and do use it but it is frustrating that Netgear never followed through with their "promised" firmware fix per the document I referenced. It is a PITA to deal with the off/on status for Private Relay when it should have been fixed in the code. I am sure companies like Apple and Netgear talk about changes in OS and firmware but I have found Netgear to be very slow at implementing fixes now and in the past that affect millions of users.
Aug 09, 2025Guru - Experienced User
I've never had to disable Private Relay. Only WiFI Private IP address. Haven't seen any issues to day with Private Relay being enabled all the time. Private Relay is a Apple feature, and nothing NG would be able to change.
Also there is newer iOS for apple devices that support it. My iPhone 12 Pro Max is on 18.6 currently. iOS 15 is 4 years old and by now, hopefully I would think that newer iOS versions are not effected by how NG FW operates with there Private Relay features.
Also the Orbi AC series is not EoL so you'll not see any more updates unless there is some major security issue. So use the system if it works for you and fits your needs. THere maybe some 3rd party FW providers like OpenWRT or DD-WRT that may have support for the 40 series. Something you check with them about. If not, you'll need to find something new gen at some point.
Good Luck.
