Reyesani
Jan 04, 2019Follower
network connections
System is Actually the RBK20W-100NAS
After a frustating installation and lengthy(more than 3 hours & two stump agents) troubleshooting latenight early morning phone conversation with my internet pr...
Jan 04, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Advanced Tab/Advanced Settings/Wireless Settings
