aruit
Jun 25, 2018Guide
Network Map
My current setup is an Orbi Router with 3 Satellites.
Two Satellites are connectes to the Router and the third Satellite is connect to another Satellite.
The whole system is functioning OK, none ...
- Sep 29, 2018
Problem solved in new Orbi App 2.2.4.397
DarrenM
Jun 25, 2018Sr. NETGEAR Moderator
Have you tried to power reset or resync that satellite to the router? Also make sure all units have the same version of firmware.
DarrenM
- aruitJun 27, 2018Guide
Yes, all units, Router and three Satellites are the same firmware version.
I have done a power reset of this third Satellite, but with the same result.
