aruit
Jun 25, 2018Guide
Network Map
My current setup is an Orbi Router with 3 Satellites.
Two Satellites are connectes to the Router and the third Satellite is connect to another Satellite.
The whole system is functioning OK, none ...
- Sep 29, 2018
Problem solved in new Orbi App 2.2.4.397
DarrenM
Jun 27, 2018Sr. NETGEAR Moderator
I may need to get you in contact with support I have sent you a PM.
DarrenM
