rayr6900
Aug 17, 2020Aspirant
Network Name vs. SSIDs
As I mentioned previously I am a network novice. I was attempting to separate devices onto either the 2.4G or 5G networks. Both the 2.4G and 5G have unique SSIDs and the network name for both SSIDs is identical. When I search for a network on my phone or laptop they both show the network name and not the SSID. I thought I logged in to a SSID and not the network name. Hence how do I separate the devices onto either 2.4G or 5G? How do I change the network name?
Thanks, novice Ray
With the orbi devcies, you don't. Especially if you're a novice. There used to be a way around it using telenet but it could cause issues and usually updating firmware caused the fix to revert.
So for a novice, let it use the single ssid function. It'll bandsteer devices between the 2.4ghz and 5ghz as needed based on speed and distance requirements.
rayr6900 wrote:I was attempting to separate devices onto either the 2.4G or 5G networks. Both the 2.4G and 5G have unique SSIDs and the network name for both SSIDs is identical. When I search for a network on my phone or laptop they both show the network name and not the SSID.
This may be a terminology issue. On this forum we tend to use "Network Name" and SSID interchangably. On the Orbi product label, it is shown as "SSID". All Orbi units broadcast the same SSID on every user radio channel. When you scan WiFi networks, this SSID will appear on two radios for each Orbi (router, satellite). What looks like a MAC address is actually the BSS, which is unique for each radio channel.
https://en.wikipedia.org/wiki/Service_set_(802.11_network)#SSID
- rayr6900Aspirant
Thank you CrimpOn (Master). This better explains the issue to me as a novice. I've been involved in this industry since '69 and a network user since the beginning. I did say user. My network experience basically started when I retired and started a home network. Most of the time I've assistence from my son and son-in-law. Both have moved so their assistance is limited. I started playing with my home network after a service call from our network provider. It appeared the netwrk was dropping our streaming service. The service tech suggested we rename our 2.4G and 5G so the devices would not be confused as to which one to use.
At this time I believe I have everything back to the way it was initially setup.
Again, thank you!
rayr6900 wrote:The service tech suggested we rename our 2.4G and 5G so the devices would not be confused as to which one to use.
The Tech had good intentions, but faulty reasoning. Let's suppose I can call you with my cell phone or with my house phone. Both will connect and we can talk. Does it matter whether I use the cell phone or the house phone? Suppose I am "confused" and pick the house phone rather than the cell phone. We still can talk.
If a connection has enough bandwidth to stream, it will stream.
If a streaming problem remains, please describe the situation. There are some really knowledgeable people who participate in the forum and "have seen everything."
- MstrbigMaster
I have nightmares over what I've seen:smileywink::smileylol:
