RonKirkpatrick's avatar
Sep 07, 2017
Network resets
For my own reasons I have my RBR50 configured to run on the network range of 192.168.100.x. Twice now the network range has been reset to 192.168.1.x with a message about the reason being the old range is causing conflict problems with the ISP. Since the entire 192.168.x.x is both RESERVED and PRIVATE and the ORBI is suppose to be handling NAT translation, why would Netgear even think that this is an issue?
    • RonKirkpatrick's avatar
      RonKirkpatrick
      Uh, the modem is on the 71.63.x.x side of the router. I would be very much surprised that a modem on the public side of the router would be using a non-routable ip address.
      • st_shaw's avatar
        st_shaw
        Master
        Be surprised then. For example, all the CenturyLink modems have a non-routable IP address assigned to their switched ports (192.168.0.1) which can used to access the modem when the modem is in bridged mode. Any device (such as Orbi) plugged into the modem will get a WAN IP via DHCP.
