Mar 01, 2019Guru - Experienced User
New - NetGear Orbi 20/40 Series Firmware Version 2.3.0.28
This new version of FW is ONLY for the 20 and 40 series Orbi systems. RBR20, RBS20, RBK20, RBK22, RBK23, RBR40, RBS40,RBK40, RBK43, RBK44
New Features and Enhancements:
Adds customer firmwa...
raven_au
Mar 01, 2019Virtuoso
I updated to this firmware on my RBS40 when I updated my RBK50 to v2.3.0.32, several days ago now.
As I have said elsewhere I'm not yet sure if a factory default reset and reconfigure will be needed due to some odd behaviours.
Overall the RBR50, RBS50 and RBS40 are working adequately without the re-configure.
Mar 02, 2019Guru - Experienced User
Good to hear. Hoping a reset isn't needed. Just if odd or problems seem to appear, give a reset a try. Remember, save off the routers config to file before resetting. Can help save time.
