Mar 01, 2019Guru - Experienced User
New - NetGear Orbi 20/40 Series Firmware Version 2.3.0.28
This new version of FW is ONLY for the 20 and 40 series Orbi systems. RBR20, RBS20, RBK20, RBK22, RBK23, RBR40, RBS40,RBK40, RBK43, RBK44
New Features and Enhancements:
Adds customer firmwa...
RedBatman89
Mar 09, 2019Guide
One more thing I'm notcing since the last update is that I'm getting a lot of DOS attack logs now. Here are some of the IP address that are attacking me
208.89.12.137
37.49.228.162
13.124.33.60
43.228.66.23
185.94.111.1
These are just a few from today, now I checked on https://www.iplocation.net/ to find out where they where and they are coming from all over across the globe. With one being from Seoul Korea, now thankfully its not happening every minute but none the less its a little nerver racking, should I be concerned?
Mar 09, 2019Guru - Experienced User
If you updated FW, I would factory reset both RBS and RBR and setup from scratch and see if you notice any changes.
Be sure to enable Beamforming and MIMO.
208.89.12.137
37.49.228.162
13.124.33.60
43.228.66.23
185.94.111.1
- RedBatman89Mar 09, 2019Guide
Well my modem is an Arris SB6190 and my ISP is Comcast. Like I said they are not happening every minute just every couple of hours I will get these then it goes awhile for awhile.
- FURRYe38Mar 10, 2019Guru - Experienced User
Might contact your ISP and have them change your IP address on the modem.
FYI about your 6190:
- RedBatman89Mar 10, 2019GuideOh I didn't rent it from them. I bought it two years ago.
