Mar 01, 2019Guru - Experienced User
New - NetGear Orbi 20/40 Series Firmware Version 2.3.0.28
This new version of FW is ONLY for the 20 and 40 series Orbi systems. RBR20, RBS20, RBK20, RBK22, RBK23, RBR40, RBS40,RBK40, RBK43, RBK44
New Features and Enhancements:
Adds customer firmwa...
DickDuke
Mar 22, 2019Apprentice
Modem is a Rogers branded Hitron.
Satellites are between 20 and 35 feet.
The RBW30 is kinda my “bonus” satellite. I could get by without it, but it gives me a slightly better connection in the bedroom.
Its a a bit overkill for the size of my condo, but the condo is two floors, with rebar concrete floor, and steel studs in the walls.
In retrospect the RBK50 would have made more sense, but I’m not ready to spend that much money all over again, for no performance gain.
Mar 22, 2019Guru - Experienced User
Ok. Hopefully will work well. Keep the distances at 30 feet. The RBR can cover a good range.
