Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
alstsmith
Feb 25, 2019Apprentice
Satellite manually updated fine, but the router update doesn't work. I get the message
"Firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I'm defintiely trying to upload the RBR firmware not the RBS one.
You do have a 50 series Orbi system correct?
What browser are you using? Try IE11, FF or Opera.
Besure to clear ALL browser caches, then exit the browser then re-open it then try again.
