Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
kolella
Feb 25, 2019Apprentice
I was able to update satellite but it won't update the router "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.". (file used for router was extraced from RBR50-V2.3.0.32.zip)
You do have a 50 series Orbi correct?
