Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
kolella
Feb 25, 2019Apprentice
Do you personaly have a 50 series router/satellite. Did you try the files included in the link you posted? or do joust post precompiled answers?
Just confirming that you have a 50 series Orbi system is all. I've tagged the mod's on this.
Thanks.
- kolellaFeb 25, 2019Apprentice
I've already lost one hour of my time to revert the satellite back to firmware 2.1.2 ...
- FURRYe38Feb 25, 2019Guru - Experienced User
Try this:
FW 2.21.212 you can download it from here https://www.dropbox.com/s/34qdnx73uikusf7/RBR50-V2.2.1.212.zip?dl=0
Then apply v32...
- MarkC1024Feb 25, 2019Luminary
That was the ticket - thanks!
