Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Just confirming that you have a 50 series Orbi system is all. I've tagged the mod's on this.
Thanks.
kolella wrote:
Do you personaly have a 50 series router/satellite. Did you try the files included in the link you posted? or do joust post precompiled answers?
kolella
Feb 25, 2019Apprentice
I've already lost one hour of my time to revert the satellite back to firmware 2.1.2 ...
- FURRYe38Feb 25, 2019Guru - Experienced User
Try this:
FW 2.21.212 you can download it from here https://www.dropbox.com/s/34qdnx73uikusf7/RBR50-V2.2.1.212.zip?dl=0
Then apply v32...
- MarkC1024Feb 25, 2019Luminary
That was the ticket - thanks!
