Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
You do have a 50 series Orbi correct?
kolella wrote:
I was able to update satellite but it won't update the router "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.". (file used for router was extraced from RBR50-V2.3.0.32.zip)
CrimpOn
Yes, I have the RBR50 and RBS50. My reason for asking is perhaps more "idle curiosity" than anything else. For two years now, my Orbi has silently updated firmware a number of time. I note that some community members recommend manually downloading and installing the files (sometimes even suggesting a factory reset as part of the process). When this thread appeared, I logged into the RBR50 and checked "Advanced->Administration->Firmware Update. I know there is probably an internal clock setting that prevents every RBR50 from hitting the download site at the same instant (i.e. spread the downloads over a period of time, perhaps even a week or more). I just thought it fascinating that manually checking for new firmware would return "nope. nothing available."
The beta testers seem positive about this firmware. My personal practice has been to let the public release unveil any "oops" moments before taking any action. (Such as the comment a minute ago that the satellite updated fine and the router firmware seemed to be an invalid file.)
