Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
This was posted from another thread from a forum Moderator
"The 2.3.0.32 FW you received is the offical FW not a beta you received it as part of limited FW push to test the FW process."
So NG seems to be limiting the push. To whom or how many, we'll not now probably.
You'll have to keep checking to see. Who know when everyones 50 series will see it in the autoupdate. :smileyfrustrated:
Chetter
Feb 25, 2019Tutor
Yup, I have the same. Manual update -> sattelite updated from 2.2.1.210 to 2.3.0.32 without problems. Router won't update. "This firmware file is incorrect".
Tried cleaning cache, tried different browsers, rebooted router, and my Orbi is not ISP branded.
I have a feeling issue is on NG side.
