Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
alstsmith
Feb 25, 2019Apprentice
Satellite manually updated fine, but the router update doesn't work. I get the message
"Firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I'm defintiely trying to upload the RBR firmware not the RBS one.
Blanca_O
Feb 25, 2019NETGEAR Employee Retired
Hi All,
There is an intermediate firmware that need to be loaded first to manually update the firmware 2.3.0.32. The said firmware should be available too in our support site. However, upon checking, it is not yet posted.
Let me check this with the team and will get back for more information.
Thank you!
Blanca
Community Team
