Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
 FW 2.3.0.32 is now available on our support site :
 https://www.netgear.com/support/product/RBK50.aspx#download
 RBR/RBS 50 Series Only.
 To manually update the firmware, there is a need to ...
Try the intermediate v212 file before applying the .v32 file when v212 becomes available.
NomadTech wrote:
Firmware is available on Netgear website specifically for manual update.
My 2 sattelites update fine, router reports Firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product, so it will NOT update. Obviously the file is bad.
I tried various browsers and also before and after restarting the system.
Chetter
Feb 25, 2019Tutor
FURRYe38 wrote:
Try the intermediate v212 file before applying the .v32 file.
And how do i get it? Share the link please.
- FURRYe38Feb 25, 2019Guru - Experienced User
Waiting on NG to post it...Please be patient.
- ErnestTheGreatFeb 25, 2019NETGEAR Employee Retired
Looks like the 2.2.1.212 FW is not posted on support site yet. For those that need the RBR50 FW 2.21.212 you can download it from here https://www.dropbox.com/s/34qdnx73uikusf7/RBR50-V2.2.1.212.zip?dl=0
- ChetterFeb 25, 2019Tutor
Hi, it worked thanks. Will see if any issues with v32.
Try this:
