Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
alstsmith
Feb 25, 2019Apprentice
Satellite manually updated fine, but the router update doesn't work. I get the message
"Firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I'm defintiely trying to upload the RBR firmware not the RBS one.
v212 needs to be applied to the RBR, then you can apply v32:
FW 2.21.212 you can download it from here https://www.dropbox.com/s/34qdnx73uikusf7/RBR50-V2.2.1.212.zip?dl=0
- geggerMar 14, 2019Aspirant
downloading the other firmware worked
- FURRYe38Mar 14, 2019Guru - Experienced User
the firmware 2.2.1.212 prior to uploading the the new firmware. Did a full resedt and i too think my signal is less than prior. I need to do some some more analytics on this . My wife does a lot of zoom, and the drops keep locking her up. I have had 3 drops i know of since the firmware upgrade. I was asuured by a tech the firmware would cure the drops. Small home with 3 very expensive wifi, should be a breeze. Google wifi was better than the orbi. I am going to hardwire the wifes office, and if performance doesnt imporove scrapping an putting goole wifi back in. thanks for your efforts to help
- martinhjApr 01, 2019Luminary
I cannot activate Armor with this firmware....I just get invalid input. Have even factory reset it with no joy
