Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
ErnestTheGreat
Feb 25, 2019NETGEAR Employee Retired
Looks like the 2.2.1.212 FW is not posted on support site yet. For those that need the RBR50 FW 2.21.212 you can download it from here https://www.dropbox.com/s/34qdnx73uikusf7/RBR50-V2.2.1.212.zip?dl=0
Chetter
Feb 25, 2019Tutor
Hi, it worked thanks. Will see if any issues with v32.
