Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
The auto update process maybe incorrectly reading or reporting what's on currently on the RBS. I would leave it for now and check back at a later date.
IF you updated the FW on the RBS first then RBR and things are working, you should be ok.
DaytonaZ33 wrote:
The update seemed to go OK to .32 on both the router and satellite, but now when I view the check for update page on my router AFTER the .32 update, it shows the satellite as being on 2.3.0.32 with an "Update Failed" status. The router shows "No new firmware update available" correctly.
Tried all the usual stuff, reset to factory, did a manual .32 update over the automatic one, etc. All the upgrades/resets happen fine, but it still won't check to see if it has the latest firmware after being on .32
Orbi RBK50 system with one satellite connected via ethernet backhaul.
larryindublin
Feb 25, 2019Luminary
Same here:
