Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
pdawg17
Feb 25, 2019Guide
So I updated the router using the file from dropbox but now my satellite says "waiting for connection" probably because it isn't on the same firmware as the router. What do I do now?
MarkC1024
Feb 25, 2019Luminary
I did both my satelites first and they came up just fine with the router on the orginal 2.2 firmware. I then did the incremental update pulled from dropbox and then the final in 2 successive steps. Everything is working fine - so far.
