Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
rchorowitz
Feb 26, 2019Aspirant
Does 2.3.x exist? I cannot find it. The instability of the internet connection to the router/WiFi makes this entire system worthless
- FURRYe38Feb 26, 2019Guru - Experienced User
NG pulled v32 for unknown reasons.
If your having problems with your Orbi system, please make a new post in the main forum and lets see if we can help you figure out the problem.
Hoping NG will re-post the v32 update soon. Please be patient.
- ChetterFeb 26, 2019Tutor
Hello All,
Just decided to give a feedback after almost 24 hrs. with v32.
So far had no issues. DL/UL speeds same on all devices.
PS: after upgrading I did factory reset, if that matters.
Will revert if any issues.
Cheers.
Awesome, thanks for the feedback. Let us know if you see problems before reverting back.
Chetter wrote:
Hello All,
Cheers.
