Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
ErnestTheGreat
Feb 27, 2019NETGEAR Employee Retired
Please note that Orbi firmware 2.3.0.32 has been pulled from Netgear Orbi support page due to lack of details in the release notes regarding the update process required to manually update your Orbi units from 2.2.1.210 firmware to 2.3.0.32. The 2.3.0.32 firmware will be restored and made available on the support page once the release notes have been updated to include the appropriate instructions for manually updating your Orbi to 2.3.0.32 firmware.
Shotround
Feb 27, 2019Apprentice
Factory reset of router via GUI needed in my case. I did not reset the satellites. Router set in Dmz of isp gateway.
I flashed it before going to bed the other day. Through the night and until reset, I received nest disconnected emails. Since reset i have yet to receive email about nest disconnected. The reset is probably more about the base OS than netgear. Still need a few more days to see if internet loss is resolved.
- FURRYe38Feb 27, 2019Guru - Experienced User
Thanks for letting us know. Yes, I believe a reset and setup from scratch may still be needed for some after the FW update. :smileyfrustrated:
