Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Shotround
Feb 27, 2019Apprentice
Factory reset of router via GUI needed in my case. I did not reset the satellites. Router set in Dmz of isp gateway.
I flashed it before going to bed the other day. Through the night and until reset, I received nest disconnected emails. Since reset i have yet to receive email about nest disconnected. The reset is probably more about the base OS than netgear. Still need a few more days to see if internet loss is resolved.
Feb 27, 2019Guru - Experienced User
Thanks for letting us know. Yes, I believe a reset and setup from scratch may still be needed for some after the FW update. :smileyfrustrated:
