Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
SkywalkerPD
Feb 28, 2019Apprentice
Note:
If you’re manually updating the firmware using a browser, you cannot update the firmware directly to v2.3.0.32. You must first update the firmware to v2.2.1.212. After updating the firmware v2.2.1.212, your Orbi router will reboot, and then you can update to v2.3.0.32.
Ok I get that, but why is there no official post/link to this 2.2.1.212 firmware? And do I have to install 212 on the router and the satelite or only on the router?
TC_in_Montana
Feb 28, 2019Virtuoso
The only place I found a link for v2.2.1.212 in the NG support pages is to go to Support, Orbi, and select RBK53. Once on that page, click on Downloads. Both the 2.2.1.212 and 2.3.0.32 links are there.
Here is a link: https://www.netgear.com/support/product/RBK53.aspx#download
- gr8shoFeb 28, 2019VirtuosoInteresting. The release notes for the interim version clearly denote the intent.
I guess it’s safe to apply now on the RBK50 as well?- Chuck_MFeb 28, 2019Mentor
It has been running like a champ on mine since day 1.
- FURRYe38Feb 28, 2019Guru - Experienced User
Also v212 is posted in the main download section for the RBR50 series as well. Users need to download this and apply this first to the RBR50 then apply v32 on the RBR.
Of course, don't forget to update the RBS satellite first before upgrading the RBR.
