Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Feb 28, 2019Guru - Experienced User
v32 has been reposted:
https://kb.netgear.com/000060603/RBR50-RBS50-Firmware-Version-2-3-0-32
This is for both RBR50 and RBK50 series systems only.
- gr8shoFeb 28, 2019Virtuoso
Odd that the support document can be gotten to properly from the RBK53 product page but not from the RBK50 one. And when you open, it clearly states intended for
RBR50 / RBS50 Firmware Version 2.3.0.32
Anyhoo, diving into the deep end now. And...
Router Firmware Version
V2.3.0.32- FURRYe38Feb 28, 2019Guru - Experienced User
The 50 series is all inclusive. K is for Kit. Which is the box with a router and 1 or two satellites in the box.
This includes the RBK50, RBK53, RBK50V, and RBK52W. Which the actual phsycial models in each of these kits is the RBR50 and RSB50.
V2.3.0.32
Two notable things I noticed immediately. Apparently the new firmware doesn't like the default password provided and initially offered. I had used the option to select the original wifi password for admin access. I'll deal with that one later.
Second was a popup for something called Armor I think. Can't say I've ever seen an upsell notice during any form of firmware update, so this is a new one on me.
Everything appears operational, although I'll get around to doing a factory reset on both boxes later on to be safe.
And yes I agree the connected device details look better now in the iPhone app.
Cheers.
Let us know how it goes after a factory reset and walk thru the setup wizard. Input new values here.
Read the release notes for new features that may have been added. :smileywink:
