Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Feb 28, 2019Guru - Experienced User
v32 has been reposted:
https://kb.netgear.com/000060603/RBR50-RBS50-Firmware-Version-2-3-0-32
This is for both RBR50 and RBK50 series systems only.
gr8sho
Feb 28, 2019Virtuoso
Odd that the support document can be gotten to properly from the RBK53 product page but not from the RBK50 one. And when you open, it clearly states intended for
RBR50 / RBS50 Firmware Version 2.3.0.32
Anyhoo, diving into the deep end now. And...
Router Firmware Version
V2.3.0.32
