Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
BrendonSF
Feb 28, 2019Guide
For what it's worth, the new 2.3.0.32 firmware is working flawlessly for me so far.
Feb 28, 2019Guru - Experienced User
Just curious, did you manually update your system or was it Auto Updated?
- FURRYe38Feb 28, 2019Guru - Experienced User
Did you factory reset after the Update or just apply and continue?
BrendonSF wrote:
FURRYe38: I manually applied the update.
- BrendonSFFeb 28, 2019Guide
I just applied the update. No indication that a factory reset is necessary at this point, though I may eventually do one just for good measure if I'm feeling ambitious.
Perhaps worth noting is that when I upgraded to 2.2.1.20 I performed a reset at that time.
