Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
gr8sho
Feb 28, 2019Virtuoso
FURRYe38 wrote:
Either method does the same thing...
Damit1 wrote:
Does a reset from GUI would make it right?
or got to be HARD RESET from Reset hole
I have a question about this as well. Many functions in the management console have a section for the base and onther for the satellite. On the backup settings page no disstinction is made. Does the procedure stepwise reset both devices and reboot? I assume yes. This will be the first time doing setup from PC, but as I said in prior post, I'm intenting to use the defaults provided as much as possible. I also expect the setup process to automatically detect the hosts LAN subnet and automatically switch to the 10.0.0.x subnet.
Feb 28, 2019Guru - Experienced User
I believe the RBR ui only resets the RBR. I don't think it sends the reset command to the satelite(s), however maybe this has changed in recent FW versions. Somthing to try.
I like using the Reset thru the UI as most of the time I'm wired with the router and can set it up from scratch after the reset or load a saved config file.
Again, ERASE in the UI has been in the UI on most all NG routers and WiFi since the beginning. Same goes for other router mfrs.
