Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Beer79
Mar 05, 2019Aspirant
I have also noticed drop in WiFi performance, this happened before the latest firmware. Satellite and backhaul are all showing strong 5ghz performance, but on the main router the 5ghz performance has been halved even when right on top of the router. Not sure if the internal 5ghz radio has failed? 2.4ghz is strong across the board, have done factory resets have tried to revert firmware back to older versions but still nothing seems to improve the 5ghZ signal strength on the router.
walkerx
Mar 05, 2019Guide
when i get round to updating to latest firmware (just monitoring the connection statuses on current firmware, etc) if i need to perform a factory reset, can you use the configuration backup and restore without issues
- Chuck_MMar 05, 2019Mentor
Yes but you shouldnt need to factory reset.
