Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
walkerx
Mar 05, 2019Guide
when i get round to updating to latest firmware (just monitoring the connection statuses on current firmware, etc) if i need to perform a factory reset, can you use the configuration backup and restore without issues
Chuck_M
Mar 05, 2019Mentor
Yes but you shouldnt need to factory reset.
