Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
orbilov
Mar 05, 2019Apprentice
If performance is bad at point blank range it does sound like a hardware issue. Is the hardware under warranty?
Chuck_M
Mar 05, 2019Mentor
You may need to explain a few things.... not sure when you purchased your unit... it comes with a period of warranty.
If performance is bad, I would start out by updating firmware to the .32 version and then fully explaining your setup here and what you think your issues are.
I would do that under a new thread to gain the full attention of all.
