Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Damit1
Mar 05, 2019Apprentice
Had to revert back to 2.2.1.210 to get my WIFI speeds back.
Restored the FW plus a factory default.
Sadly, for every upgrade/downgrade got to be a whole procedure attached.
it seems my orbi is suffering some speed lose becase of LAN WAN (instead of WAN LAN used to be) connection, but it is much better now.
It is that or having HARD WIRE issues (barely use them currently), I'll have that.
JMU1998
Mar 06, 2019Luminary
Just updated to latest firmware and performed factory reset now my VOIP call drop on my wired laptop connected by wire to Orbi_Sattalite. I have Orbi in AP mode and have Googlefiber gigabit up/down never had this issue before, even WebEx calls on my laptop dropping. everything has been rebooted, googlefiberbox , laptop, Orbi.
