Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
JammasterC
Mar 07, 2019Star
Ugh please no Auto Update!
I'm happy here on V2.2.1.210
My house is working fine.
mastervisa30
Mar 08, 2019Luminary
Firmware Version 2.3.0.32 didnt work for me,i have droops out all the time on my 2 satellites,
poor signal and not connected all the time,my kids and wife are going mad on me.have tried reset and asked people on this forum for help but still have the same problem.
But i was going back to firmware version 2.2.1.210 and now its working again.
Iv been using orbi a wile now and the firmwares is a nightmare sometimes.
I called my store i can send it back if i want?but i dont know?
Maybe i should go for aimesh asus?ore wait for the new wifi 6 ax orbi/asus
this is startimg to be a nightmare,have been working long time now and suddenly droops out on the new firmare.
I like to test but not my wife and kids:)
- raven_auMar 08, 2019Virtuoso
I don't think you will be happy with AiMesh.
I have three ASUS devices and I try each new firmware release.
They don't last very long before I swicth back to somehing else.
The Velops used to be fairly good but lately they get kicked out in favour of the Orbis within a day or two.
People have spoken very highly of Google mesh devices and I suspect the Ubiquiti Amplifi HD mesh devices are fairly good too but I don't have any of these.
But, now that I've identified the settings to leave off for me to have a stable network, I'm staying with the Orbi for a while.
From what I have seen in the forums what works for me likely doesn't work for others and I believe many of the problems people have are due to one or more particular devices that don't play well with the Obi. Consequently Netgear must play "wait for Qualcomm to fix it" game that takes a long time, not that Netgear are all that quick at fixing things either, a double gotcha.
- FURRYe38Mar 08, 2019Guru - Experienced User
Did you factory reset the Orbi system and setup from scratch after loading v32? Try this next time when you upgrade. This clears out possible problems after upgrading FW. Others are reporting good operation after ugprading to v32 and doing a factory reset and setup from scratch.
- mastervisa30Mar 12, 2019Luminary
sorry late answer,i always do factory reset,and new setup everytime i install new firmware its standard for me
:)im still on firmware version 2.2.1.210 no dropps out on my satellites,working great so far now :)
