Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
tgltgl
Mar 08, 2019Star
I'm a new Orbi user. Set everything up few days ago and last night did a two step manual firmware upgrade to this latest version. Everything seems to operate ok so far, although one iphone had to be rebooted to see the wifi (sounds crazy that was only required for one wifi device). Anyhow, I noticed the Armor advertised in the new firmware so wanted to see what that was about but have no idea how to activate it. It does not seem possible at all via computer (browser), so I downloaded the Orbi app to my Android phone to see if that would work. I was able to connect to the router and app seems to work fine, with exception when I select Security button I get message 'Orbi - Device is off-line'. No idea what to make of this since the device is obviously not off-line (I am able to use that same app to run speed test, see network map, etc).
Does Armor actually work on Orbi, or is the new firmware only placholder for service that will be rolled out to this router?
Mar 08, 2019Guru - Experienced User
I would post your question here:
- tgltglMar 08, 2019Star
Thanks for quick reply and that link. After quick read of that thread I've decided to stay away from Armor until they fix the issues. Seems pretty clear it's not ready for widespread use if basic activation types of errors are still reported - and the fact that it's not even possible to activate in browser and only on phone apps (if they happen to work) is another indication it's not ready - really hard to believe this is actually the case so maybe I'm missing something there as well.
- gr8shoMar 08, 2019Virtuoso
I don't know about that. Yes it's true that the web GUI from PC doesn't seem to do anything more than display the current state of activation. However I was able to activate my trial license from the app in iPhone. The feature can be both activated and deactivated from the app. I decided to leave mine off as I don't really get what it's doing for me other than sending messages about when new devices are joined to the network.
The activation issue is obviously not a one off when they are asking people to contact them directly (in that thread they are asking people to PM them with serial numbers). But to me the fact the you activated it but then turned if off because you don't have any idea what it is actually doing is the proof that this service is not ready. I want full transparency (and configurability) about what security service like this does or I'm not using it.
- walkerxMar 08, 2019Guide
Just quick thanks to the users on here who have tried helping resolve my issues with the orbi.
I've now sent it back as its not fit for purpose in my view. when it works, its brilliant but as is with the disconnections, app not working as should be, satellites not using ethernet backhaul when should be, its not a system i could stick with.
I've now switched to google wifi and set this up in 20 minutes (3 device system) and it's working perfectly, no drop outs, no disconnections, no constant cycling of the connection for the satellites. it seems to just work.
It's a shame the orbi's are let down my should buggy firmwares, apps and possible units as when it works as supposed to, the performance is excellent
